Joe-Bouza
Message 11 of 16 (303 Views)
Re: Basic Lane Sub-Assembly and Targets........
01-18-2013 05:01 AM in reply to: BrianHailey
Dats da one. :smileywink:
Maybe I'm reading too much between the lines but I steer clear.
In my earlier experience I used a BasiCurb and because it has no offset on the face I believe it caused corruption in my TIN, at the time.
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
BrianHailey
Message 12 of 16 (299 Views)
01-18-2013 05:50 AM in reply to: Joe-Bouza
I too stear clear of the basic subassemblies. Why? Well, I remember them causing issues several releases ago. What where those issues? I honestly don't remember.
If the only reason you are doing something is because that's the way you've always done it, you're doing it wrong.
Perhaps I should go revisit the basic subs and see if they still cause issues or not.
Brian Hailey
CAD-1.com
My Blog
Distinguished Contributor
taneum
Message 13 of 16 (286 Views)
01-18-2013 10:04 AM in reply to: Jeff_M
Jeff_M wrote:
Instead of a Basic Lane, use a UrbanSidewalk with a 0' inside width, 2' walk, 0' outside width. Attach the ret.wall to this, the sidewalk width can be set to a target.
Yep that worked Jeff.  The only thing I ran into was, I put the "shape trapezoidal" sub-assembly under the sidewalk and in my section where the urban sidewalk was gone because the wall took its place, the shape trapezoidal sub-assembly moved up in the place of the sidewalk.  I didn't get this at first but when I targeted that sub-assembly to the same target lines as my sidewalk was targeted to, the shape trapeaoidal sub-assmbly went away also.  Make sense?  Kinda wordy but I think it doing what I need it to.
Jeff_M
Message 14 of 16 (281 Views)
01-18-2013 10:24 AM in reply to: taneum
Yes, that makes sense. Glad it worked for you!
Joe-Bouza
Message 15 of 16 (267 Views)
01-19-2013 07:09 PM in reply to: fcernst
Your absolutley right Fred; they would never put anything in the program that would screw things up :smileywink:
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Joe-Bouza
Message 16 of 16 (266 Views)
01-19-2013 07:10 PM in reply to: BrianHailey
good point
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
