JamaL9722060
Message 1 of 6 (198 Views)
“Basic assembly” is not drawn correctly in the section view,
198 Views, 5 Replies
10-16-2012 02:42 PM
In the screenshot below, the “Basic assembly” is not drawn correctly in relation to the existing ground.
What might be the reason that it is not closed with the existing ground?
Thank you for the help,
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
LeafRiders
Message 2 of 6 (192 Views)
Re: “Basic assembly” is not drawn correctly in the section view,
10-16-2012 04:27 PM in reply to: JamaL9722060
To me it looks like a target isn't set properly in your Corridor Properties. Either that or there is a gap in your surface which it doesn't look like is the problem.
mathewk
Message 3 of 6 (174 Views)
10-17-2012 07:48 AM in reply to: JamaL9722060
Your surface isn't wide enough at that station.  You're using, say, a 3:1 slope and that slope will not intersect the surface because there is not enough surface.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
JamaL9722060
Message 4 of 6 (162 Views)
10-17-2012 02:24 PM in reply to: mathewk
Thank you guys for the answer. This is quite useful.
Does this affect the calculations of fill and cut then? What might other consequences be?
Firefox 20.0,
Kaspersky 2013.
mathewk
Message 5 of 6 (157 Views)
10-17-2012 02:39 PM in reply to: JamaL9722060
It will absolutely affect your volumes because there would be nothing to calculate at that station.  You NEED to make your surface larger in that area.  Either get more survey or make stuff up (fudge).
Matt Kolberg
JamaL9722060
Message 6 of 6 (131 Views)
10-19-2012 01:46 AM in reply to: mathewk
Many thanks for the valuable answers.
I tried to modify the slops of the “assembly” but sounds that the “sections” doesn’t repond!
Is there a particular way to update them according to the change in the “assembly”?
Firefox 20.0,
Kaspersky 2013.
