Valued Mentor
Valued Mentor
sjg
Message 21 of 40 (473 Views)
Re: Basic area label
04-19-2012 08:31 AM in reply to: dana.probert
Found this lisp from a previous discussion group seems to work pretty good and exactly what I was looking for, Was wondering if someone could look to see where I could eliminate the number and just display the area. Would like the area to read on the top line 43,560 SF and on the next line 1.00 AC.
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
antoniovinci
Message 22 of 40 (468 Views)
04-19-2012 09:52 AM in reply to: sjg
I've just tuned the brilliant lisp by Tcorey, in order to match the Neilyj request - run the attached file issueing SQM
neilyj
Message 23 of 40 (451 Views)
04-20-2012 12:15 AM in reply to: antoniovinci
Thanks for the update - but it doens't seem to work correctly. It displays odd results on the command line and doesn't add the text to the drawing
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
antoniovinci
Message 24 of 40 (449 Views)
04-20-2012 12:41 AM in reply to: neilyj
I'm sorry, Neil, but in my Map2006 it works perfectly, as you can see in the attached file.
If i find a free hour today, I'll try to download a C3D trial to test it: stay tuned.
neilyj
Message 25 of 40 (444 Views)
04-20-2012 12:54 AM in reply to: antoniovinci
No problem
neilyj
antoniovinci
Message 26 of 40 (442 Views)
04-20-2012 01:00 AM in reply to: neilyj
Basing myself on your screenshot, I corrected the routine: please run it with SQM4NEIL
It doesn't work for me under Map2006, and what about you?
P.S.
To see the "2" superscript, you must use a font supporting Unicode, e.g. simplex.shx or Truetype.
neilyj
Message 27 of 40 (437 Views)
04-20-2012 01:51 AM in reply to: sjg
Getting there - but the text height as input (5 in this case) is also passed to the rotation parameter:smileysad:
neilyj
antoniovinci
Message 28 of 40 (428 Views)
04-20-2012 02:05 AM in reply to: neilyj
As stated by Timmy "The current text style must have a 0 height", but actually yours appears as follows:
so try to set 0 in your ANN2MM style, then run the attached file with AREALABEL
neilyj
Message 29 of 40 (423 Views)
04-20-2012 02:27 AM in reply to: antoniovinci
Many thanks - that works fine now:smileyhappy:
neilyj
antoniovinci
Message 30 of 40 (419 Views)
04-20-2012 02:39 AM in reply to: neilyj
You are welcome, and pay attention to this point: in the last AREALABEL.LSP I've added a command to erase the temporary boundary at each loop, so the drawing stays light.
