I'm labeling a baseline station where the Stations 2+00 and PC 2+00 are the same point and label twice (See pic).
I dont' want to show the Sta. 2+00 jut the PC 2+00 sta. Do I have to create a label style or is there an option bury somewhere
that I can turn off or something. The only way I can think up to accomplish this, is exploding the stations label and delete the 2+00 station.
Thanks.
Neptuno8881
Solved by Jay_B. Go to Solution.
An easy way to do hide the extra label is to:
Left click the Major Station Label while holding ctrl key (This selects only the 2+00) > Rt. click > "Label Properties" > Visible > False.
they're part of different geometry that's included in your label set (Major Station labels & Horiz Geom labels). If you never want to see it, you could use your Ctl key, select the label & delete it. If you don't use your control key, it will delete all the Major staton labels. The Ctl key allows you to select individual labels. The only other way is to not have them part of your label set. Using your Ctl key is much more expedient. If you relabel the alignment, they'll come back tho.
