How do I change the surface style when I import surfaces permanently. When I was using 2012 the base surface style was "Border Only" but now in 2014 using the template I was given and TOLD to use, it brings all imported surfaces to "Triangles and points". Where in the settings can this be changed and I will change the template. I know that part of things will not affect anything except for the annoying pain of having to change the style every time I import a surface.
Solved by WyldeParnelle. Go to Solution.
I think I am getting warm as to where this is but it's when I use "_AeccLandXMLIn Importing Surfaces" I want to change what surface style it imports.
figured it out...I simply replaced it in settings to what I want and boom, done.
