Civil 3D Forum
Band style in Profiles - staggering labels
2 REPLIES 2
hartmut.dickel
1555 Views, 2 Replies
Hi
I have a question regarding the Band style in Profiles.
When I generate a band and the points that need to be labelled are very close to each other there is the possibility to stagger the labels (left, right, to both sides).
This works as I would expect it to.
What I haven’t been able to determine is whether it is possible to adjust or influence the spacing between the staggered labels.
I have attached a sketch showing which spacing (marked red) that I mean.
Perhaps someone can help me here? Thanks!
Best regards
Hartmut
2 REPLIES 2
Jay_B
in reply to: hartmut.dickel
Adjust the X values in the Band Style Profile Data.
Settings Tab of Toolspace>Profile View>Band Styles>Profile Data>Select the Style or Styles in use>Band Details Tab.
For each Labels & Ticks category Edit "ProfileX Elevation" modify the Major Station, Minor Station etc.,  selecting "Compose Label" here:
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
hartmut.dickel
in reply to: Jay_B
Hi Jay
Thanks’ for your reply.
This isn't exactly what I wanted to do. I don’t want to change the position of the text relative to the marker.
But your hint helps me to find the solution.
The space between the staggered labels depends on the value in the “Border” section, even if the Visibilty attribute” of the border is set to “FALSE”.
GAP 0.75mm (red = Marker):
GAP 0.00mm (red = Marker):
Best regards
Hartmut
Rail Community
