How do I get my band set to show only existing and proposed for the following
Crown
Edge of Carriageway
Top of Kerb
Back of Kerb
Back of Footway
My assemblies use point codes
Crown
EOC
TopofKerb
BackofKerb
BOF
respectively
Regards
Evan
Band Sets are used in a profile view. From what you've posted, I gather you have cross section views set up, and want the EG/FG elevations labeled at each Point Code along the x-section.
Here's a video demonstrating how to get to and edit a style to apply to your situation. (You will have to edit and create it to tailor it to your needs, I just simply showed you how to get there and how to add a point code to the label definition)
http://www.screencast.com/t/VdmM3ZAuTz0
I think this is along the lines of what you're seeking.
HTH
Do you want to add levels at defined points in section views 'data band' ?
If yes, you can try this method:
1. Create an band set style with no content in it
2. Edit point code set styles
3. edit 'elevation' content's anchor point to 'section view bottom'
4. then add 'Y offset' value to the same 'elevation'
Then you can see section view with data band containing 'elevations for only defined points'
Hope this will help you!
