I've found that with Mtext with a mask as well as some label objects with masks, you will need to adjust the Draworder to bring the Mtext/Label object to the front or sometimes, the C3D object to the back OR sometimes change the order so that the Mtext/Label is in Front of the C3D object.
Kevin
