Civil 3D Forum
Average elevation for zoning analysis
34 REPLIES 34
Message 1 of 35
Joe-Bouza
1333 Views, 34 Replies
We have to compute the average elevation along the front, sides and rear of a proposed building envelope to calculate the required set back.
Right now I am setting FL with elevation nodes at the required interval, assigning EG elevation and pasting from the panorama to excel to compute the average.
Is there a way I could create a toolbox report to do this? Maybe even from a profile report?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
34 REPLIES 34
Message 21 of 35
fcernst
in reply to: troma
..But you also need to divide by the number of elevations..
No, you simply divide by the sum of the weights.
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
Message 22 of 35
troma
in reply to: fcernst
Sorry, yes, you're right.
Mark Green
Working on Civil 3D in Canada
Message 23 of 35
brian.strandberg
in reply to: troma
How about this work flow?  It is a little convoluted but it works.
1. Draw a polyline the length of the frontage (make sure this polyline is contained within your surface.
2. Create a block called _point.  The block should just have an autocad point at the insertion point of the block.
3. Use the measure command to insert the _point block at 1 foot intervals.
4. use the _AeccMoveBlocksToSurface to move the inserted point blocks to the surface Elevation.
5. Explode all of the _point blocks.  This will leave you with autocad points at the correct elevation (the point of steps 1-4)
6. Use the CREATEPTCONVERTADESKPTS to convert your point object (at the correct elevation) to Civil 3d points.
7. Export the Civil 3d points to Excel or other spreadsheet program
8. Use excel to compute the average of the exported points.
Convoluted?  Yes, but it does do the job.
Hope this works for you.
I rarely have time to post. If what I post helps please use Accept as Solution / Like when appropriate.
Check out my Civil 3d blog at: http://c3dk.com/
Message 24 of 35
Good thought but you might want to re-read the OP 😉
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 25 of 35
AllenJessup
in reply to: jmayo-EE
@jfmayo wrote:
A 1' interval in simply insane. I know the town will typically define this standard but 1'? Come on.  🙂
A Zoning Board, Insane! Come on John. You know better than that! Smiley Very Happy Smiley LOL Smiley Surprised
Allen
Allen Jessup
CAD Manager - Designer
Message 26 of 35
AllenJessup
in reply to: Joe-Bouza
Joe,
I like the idea of a mini-Surface. But I can't think of any way to automatically label it or get in in a table. Just copy/paste from the Statistics tab.
Allen
Allen Jessup
Message 27 of 35
troma
in reply to: AllenJessup
There was a post from a different conversation recently about using pipe network structures to get elevations into a table from a surface.
Mark Green
Message 28 of 35
BrianHailey
@fcernst wrote:
Yup, the n on the bottom should have been a 2.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 29 of 35
fcernst
in reply to: BrianHailey
The two is up in the numerator.
Every instance of Z1+Z2 has to be divided by two to obtain the average of Z1 and Z2 before their average is multiplied by the specific weight (Li).
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 30 of 35
BrianHailey
I just factored out the 1/2.
GEI Consultants
My Civil 3D Blog
Message 31 of 35
fcernst
No, you can't just factor out the 1/2...
((Z1+Z2)/2)*L1 + ((Z1+Z2)/2)*L2...../(L1+L2+ ...)
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 32 of 35
BrianHailey
Sure you can.
GEI Consultants
My Civil 3D Blog
Message 33 of 35
fcernst
Oops..right my bad.
Fred Ernst, PE
C3D 2024
Ernst Engineering
Message 34 of 35
jmayo-EE
How are you doing with this? The number of data points is killer and would love to see if ur cooking anthing up over there.
All the towns we work use the 10' interval which I think if from the IBC. With fewer points the Flines and a manually filled out acad table which does all the other req'ed calcs is still faster for us since it is ready to print on the plan without adding processes to go to and from other apps. Here is a very simple example with a town that only uses the front building line in the calc.
John Mayo
Message 35 of 35
Joe-Bouza
Nothing special, but a surface does return the mean elevation so if i create a sall surface from the FL either offset or grading at 0% the average elevation is reported via surface props. I sure wish a surface label property for average elevation was available. Otherwise it doe elliminate the excel feed. Thanks for asking. Howd that thing go for you?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Rail Community
