Does anyone know how you can set the FACETDEV variable in the acaddoc.lsp file or some other automatic way? Having to set it manually every time you open a file with a pipe shown in crossing profile or section is just annoying. FACETDEV doesn't seem to be recognized by the SETVAR method like most other settings which I set in my acaddoc.lsp.
Has anyone done this?
Solved by tcorey. Go to Solution.
Solved by castled071049. Go to Solution.
We set it once in the base template, and it never changes from that setting. Been like that for years now.
This format will work for setting it through lisp:
(command "FACETDEV" "0.152")
However I don't know if it will work at the point the acaddoc.lsp is being loaded.
Allen
BTW I tried it as an environmental variable also and that didn't work either.
Allen Jessup
CAD Manager - Designer
FACETDEV is a command, not a system variable.
Use (command "FACETDEV" 1) or whatever value you want to set.
or
(vl-com-load)
(vl-cmdf "FACETDEV" 1)
Tim
Thanks guys - didn't think about it being set and sticking in the template.
The command "facetdev" 0.01 did the trick in the acaddoc.lsp
Thanks!
