Active Contributor
derel
Message 1 of 5 (287 Views)
Automatically set FACETDEV variable
287 Views, 4 Replies
10-15-2012 09:40 AM
Does anyone know how you can set the FACETDEV variable in the acaddoc.lsp file or some other automatic way? Having to set it manually every time you open a file with a pipe shown in crossing profile or section is just annoying.  FACETDEV doesn't seem to be recognized by the SETVAR method like most other settings which I set in my acaddoc.lsp.
Has anyone done this?
We set it once in the base template, and it never changes from that setting. Been like that for years now.
FACETDEV is a command, not a system variable.
Use (command "FACETDEV" 1) or whatever value you want to set.
or
(vl-com-load)
(vl-cmdf "FACETDEV" 1)
Tim
Distinguished Mentor
castled071049
Message 2 of 5 (285 Views)
Re: Automatically set FACETDEV variable
10-15-2012 09:47 AM in reply to: derel
AllenJessup
Message 3 of 5 (279 Views)
10-15-2012 10:40 AM in reply to: derel
This format will work for setting it through lisp:
(command "FACETDEV" "0.152")
However I don't know if it will work at the point the acaddoc.lsp is being loaded.
Allen
BTW I tried it as an environmental variable also and that didn't work either.
tcorey
Message 4 of 5 (277 Views)
10-15-2012 10:42 AM in reply to: derel
or
(vl-com-load)
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Contributor
derel
Message 5 of 5 (275 Views)
10-15-2012 10:43 AM in reply to: derel
Thanks guys - didn't think about it being set and sticking in the template.
The command "facetdev" 0.01 did the trick in the acaddoc.lsp
Thanks!
