Civil 3D Forum
Automatically set FACETDEV variable
4 REPLIES 4
derel
1126 Views, 4 Replies
Does anyone know how you can set the FACETDEV variable in the acaddoc.lsp file or some other automatic way? Having to set it manually every time you open a file with a pipe shown in crossing profile or section is just annoying.  FACETDEV doesn't seem to be recognized by the SETVAR method like most other settings which I set in my acaddoc.lsp.
Has anyone done this?
4 REPLIES 4
castled071049
in reply to: derel
We set it once in the base template, and it never changes from that setting. Been like that for years now.
AllenJessup
in reply to: derel
This format will work for setting it through lisp:
(command "FACETDEV" "0.152")
However I don't know if it will work at the point the acaddoc.lsp is being loaded.
Allen
BTW I tried it as an environmental variable also and that didn't work either.
Allen Jessup
CAD Manager - Designer
tcorey
in reply to: derel
FACETDEV is a command, not a system variable.
Use (command "FACETDEV" 1) or whatever value you want to set.
or
(vl-com-load)
(vl-cmdf "FACETDEV" 1)
Tim
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
derel
in reply to: derel
Thanks guys - didn't think about it being set and sticking in the template.
The command "facetdev" 0.01 did the trick in the acaddoc.lsp
Thanks!
Rail Community
