troma
Message 11 of 14 (161 Views)
Re: Automatic Save is not creating Temp files
11-16-2012 08:22 AM in reply to: AllenJessup
In my expirience the .bak files get saved to the same place as the .dwg
Is there a setting to change this?
Credit where credit is due! Give kudos or accept as solution whenever you can.
AllenJessup
Message 12 of 14 (158 Views)
11-16-2012 08:32 AM in reply to: troma
I still get .BAK files with the drawing files. The .BAK of the .SV$ files seems to be an artifact of my denying the System the right to delete files in my
mikeevans
Message 13 of 14 (148 Views)
11-16-2012 01:49 PM in reply to: RobR88
In options "Save backup copy with save" will save bak file to same directory as the originating file.
The autosave and Incremental save will save sv$ and bak files. Set incremental save as 90. This will in effect perform a full save every x minutes otherwise it will be a partial save.
The above will create and use a lot of space in the temp directory so will need deleting periodically.
Mike Evans
Civil3D 2013 / 2014 British UK
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
AllenJessup
Message 14 of 14 (145 Views)
11-16-2012 01:56 PM in reply to: AllenJessup
Something going wrong with my posts.
I still get .BAK files with the drawing files. The .BAK of the .SV$ files seems to be an artifact of my denying the System the right to delete files in my dedicated folder. The MoveBak command will change the folder for the regular .BAK files.
Allen
