I'm getting a command line message 'no solution found' when I try and create a slide line in teh Parcel Layout Tools. I have my site boundary and I'm using it to get my reference angle. Please tell me what I'm doing wrong...
Solved by Jay_B. Go to Solution.
You'll need to provide a lot more information if you want to get a meaningful answer. Can you post an image showing your parcel settings, the parcel shape, and the frontage you defined?
Thanks, I figured it out. I was using a polyline property boundary and p lines separating the lots so I exploded the polylines and it worked. I am now battleing with the label styles. I have changed the number of places after the decimal everywhere I can think of starting with the drawing settings to the styles settings, to the object settings and no change. Where is the first place I should go?
Label precision is controlled within Label Styles.
Layout Tab of the Parcel Style or Styles in use>Component Name (you wish to change)Text>Contents>click radio button>highlight contents on right>change precision to desired on left and push the updated information to right side using the right arrow icon>Apply/OK.
