AutoCAD Civil 3D General Discussion
0 Kudos
Post 1 of 3
Automatic Grading Criteria Creation
272 Views, 2 Replies
04-19-2012 12:25 PM
I have grading criteria sets that are automatically being created, and I'm just wondering why?  Even better, how do I prevent it?
They look like the following.
[Criteria Set Name]
[Criteria Set Name].1
[Criteria Set Name].2
[Criteria Set Name].1.1
[Criteria Set Name].2.1
[Criteria Set Name].2.2
Ad infinitum
It's a little obnoxious to clean them out so any help would be appreciated.
New Member
2 Kudos
Post 2 of 3
Re: Automatic Grading Criteria Creation
05-27-2014 01:22 PM in reply to: joshua.prettyman
I know this was posted over 2 years ago, but I've been having the same problem in 2014.  I think I've found a way to get rid of them, so here goes...
  1. Recover the drawing to fix an errors
  2. Use -PURGE to clean up the drawing
  3. Create a new Criteria Set or import one from another drawing - one with a different name - and create a generic Style to populate it
  4. Right-click on the Criteria Set that you can't delete and select Find References...
  5. Right-click on the reference and select Replace with...
  6. Select the new Criteria Set
  7. Use _PURGESTYLES.  Sometimes I have to run it more than once.
NOTE: _PURESTYLES WILL DELETE ALL STYLES THAT ARE NOT SPECIFIED AS A DEFAULT OR IN A COMMAND, SO BE SELECTIVE IF YOU NEED TO.  If you run it multiple times, you may be able to select the specific styles you want to delete.
Hope this helps...
*Expert Elite*
245 Kudos
Post 3 of 3
05-27-2014 01:28 PM in reply to: joshua.prettyman
I believe these are created in your file when you copy/paste grading/fline data to and from the clipboard.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
