Don Ireland
Engineering Design Technician
@Anonymous wrote:
@doni49 If you are a partner
I'm not even sure what that means so I'd guess that I'm not. 🙂 I'd be interested in seeing anything you're willing to share. Thanks!
Don Ireland
An Autodesk Reseller. Give me your email address and I will send you some stuff. If you don't want to share it on here, send me a private message.
I'm guessing the software is still too new to find much training material out there.
Don Ireland
Some more detail about what I'm getting at:
I've been tinkering with the software while I had a little bit of downtime.
I created a retangular shaped parking lot. Then I placed parking spaces along the perimter of the lot. When I used the "Parallel Row" button to create an additional row, it created another rectangular "row" of spaces. So the spaces INSIDE the rectangle were "landlocked". Is there no way to create a row that is parallel to just one side of the lot? Is there no way to remove one side of the newly created row? Or do I need to draw the new row separately?
Regarding creating a Roundabout: I saw him create it on a C3D alignment and it created the corridor. But is there no way to control the PROFILE of the approach roads? I didn't see him ID a profile to use.
Is there a way to use this to create regular roadway intersections instead of roundabouts?
These are the TYPES of things I was hoping to see training material cover. I'm sure there will be other things as I dig in to this.
Don Ireland
@Anonymous wrote:
Check and see if Savoy has any training material. This is who Autodesk purchased from.
Thanks. I just checked and all their site does is redirect to the Autodesk site which provides the same demo videos.
Oh well. I'll work my way through it. Maybe as I go along, I'll try to come up with some of my own tutorials to post. I've been wanting to get into blogging. 🙂
Don Ireland
Well I just found this answer.
When selecting the approach road location, there's an option that allows me to select the profile of the alignment.
Don Ireland
Sounds likeoffseting a pline? I wouldn't expect one leg ot he pline to offset. Perhaps the perimeter needs to be segmented? I'm guessing. My delivery hasn't arived yet, but I am excited to get it.
Have you checked out toutube? they may not be tutorials but I'm sure we can glean something from them. There must be something some of these go on for more than an hour
Joe Bouza
