When I try to sign in to Autodesk 360 from within C3d 2014 SP2 nothing happens.
Same from within C3d 2015 SP1.
Is there some setting I can change so the Autodesk 360 sign in feature works from the Autodesk 360 location on upper right of Ribbon?
Or how is one supposed to sign into 360 from within the software?
Solved by MichaelLapouge. Go to Solution.
is there an error message?
DarrenP
Darren,
No there's not even a blip @ the command line when selecting it here in 14 or 15:
do you happen to have autodesk 360 installed by chance?
DarrenP
any way you can uninstall autodesk 360 and see if it lets you sign in?
DarrenP
I thought I was on the cusp of understanding what's happening but haven't been able to quite pin it down.
The caption I posted indicates I'm logged in as Jay_B but as you can see it states "Sign into Autodesk 360" rather than "sign out".
After wondering if being logged in as Jay_B to Disc. Groups @ the same time could be creating a conflict, I logged out of Disc. Groups and now am able to Log into and out of 360 normally? This just has me more confused.
I also should mention I've been going back & forth between C3d 2015 & C3d 2014 the last couple of days experimenting w/ the Live Maps Feature and am fairly new to using 360.
I'm unable to uninstall 360 but what is recommended? I can have IT uninstall it if need be.
Thanks for your help on this Darren.
Turns out the issue seems realated to not signing out of 360 properly.
If I regularly sign out of 360 at end of day etc. then I'm able to login normally.
When I don't sign out and leave for the day, 360 gets understandably confused and acts unresponsive from within C3d.
thats wierd
and this only happens in Civil 3D?
DarrenP
C3d is the only place I've used Adesk 360 recently, I have also tried it for Infraworks but a while ago.
At the end of the day yesterday as a test, I intentionally remained logged into 360, closed all programs & locked my cpu.
Then remotely accessed cpu and tried to sign out and it was unresponsive again but I do go back and forth between 2014 & 2015.
If I'm signed into 360 in 2015, close 2015 w/out signing out of 360, then launch 2014 my name will appear on 360 sign in (in any version I open), but It will be unresponsive, then I'll have to open 2015 (or version signed into / logout of 360 & relaunch 2014?
It's all very confusing, but as long as I sign out regularly, then all is well in the 360 world.
Joe Bouza
Joe Bouza
@Joe-Bouza wrote:
Not yet.
I don't know what changed but I know the first time I tried this feature I typed GEOGRAPHICLOCATION and got a world map, now I get nothing.
i can't tell whats going on
is it possible to uninstall Autodesk 360 and see if it works?
DarrenP
Joe Bouza
Joe Bouza
and just to add a few heebie jeebies here. 😉
I uninstalled 360 last week and tried to reinstall from the disk. The reinstalled failed. I believe because the rest of the suite had a bunch of updates installed via the application manager. I get an error stating that a newer version is installed....
I think I have to unistall the entire suite to get 360 reinstalled.
John Mayo
you may have to dig down into the install and find the cloudsync.msi file to reinstall
i don't remember the exact path
something like this x64/components/adsksync
DarrenP
That did the trick. Thanks Darren. Sorry I can't give you a solution. This is Joe's thread and this is a side topic...
FYI adsync.msi was the file I found in the admin image.
John Mayo
