When Im using Autocad civil 3d 2015 as Autocad, clicking help sends me to Civil 3d help. Where is the Autocad ONLY help. I have to google everything because i cant see how to get Autocad only help in Autocad.
Solved by brice.couch. Go to Solution.
Hello DavidLofberg5147,
Try installing the AutoCAD 2015 offline help files, you can access and search them using your web browser.
AutoCAD 2015 Offline Help
Once installed, open the following file in your web browser.
file:///C:/Program Files/Autodesk/AutoCAD 2015 Help/English/Help/index.html
I hope this helps, please let me know if you have any questions.
Brice
