Really would like to start making use of the Fields autocad provides. However when labeling say an Angle of a line in Surveyor Units, I do not want the D to be displayed and show a degree symbol or %%d itself. The spacing between the N ##%%d is unnecessary too. Is there away to either modify the way the field works? Through .Net is an option im comfortable with. Or even create your own custom fields?
Thanks for any tips in advance.
John Mayo
Are you using Civil 3D or plain AutoCAD? If you have Civil 3D, there is no need to use Fields, just use the built-in labeling. If you don't use Civil 3D, then this is probably not the best discussion group in which to post your question.
I have to assume yo are using an "object" field. there is a format button in the dialog that offers several different ways. I dont have cad now, but I'm sure its there. Also there is always %%d
