StephenMark
Message 1 of 12 (877 Views)
AutoCAD Exchange Apps in Civil 3D - Ribbon Mess up
877 Views, 11 Replies
07-16-2012 04:57 PM
I have installed a number of Exchange Apps to my AutoCAD 2013 (part of Infrastructure suite Premium) - all loads nicely on to the plug-ins panel.
Back in Civil 3D 2013 however, each tool has been given its own add-ins, or plug-ins ribbon panel - not very useful after installing about 20 apps so now have 20 individual ribbon panels with a single tool on each.
How to combine them back to what AutoCAD 2013 has one  -all on the single plug-ins panel?
neilyj
Message 2 of 12 (856 Views)
Re: AutoCAD Exchange Apps in Civil 3D - Ribbon Mess up
07-16-2012 11:58 PM in reply to: StephenMark
This is a great question - I've got this annoyance in 2013 as well.
I suspect there won't be an easy fix though......
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
DarrenP
Message 3 of 12 (842 Views)
07-17-2012 06:42 AM in reply to: neilyj
me 2
Valued Mentor
TerryDotson
Message 4 of 12 (834 Views)
07-17-2012 08:58 AM in reply to: StephenMark
They were informed of that in the Beta cycle well before 2013 was released, but it apparently remains broken.
DarrenP
Message 5 of 12 (832 Views)
07-17-2012 09:05 AM in reply to: TerryDotson
it seems to be across all 2013 autocad based products
Valued Mentor
TerryDotson
Message 6 of 12 (812 Views)
07-17-2012 04:28 PM in reply to: DarrenP
Across all verticals, but base (vanilla) AutoCAD works, they all show line up in one Plug-Ins tab.
tyronebk
Message 7 of 12 (785 Views)
08-14-2012 12:10 AM in reply to: neilyj
It's actually not a difficult fix. The problem is that the Civil 3D Add-ins tab is somehow not properly configured. The solution is to simply add a new ribbon tab to your main CUI (must be the main CUI and not the enterprise). Either copy the ribbon tab from a proper ACAD.cuix or just create one with the name Plug-ins with an alias of ID_ADDINSTAB (see attached image). Now add that tab to your desired workspaces. I don't think you can simply rename the Civil 3D Add-ins tab; I recall having mixed results doing that.
The not so easy part of the solution is to get the plug-ins that you have already installed sorted out. This can be accomplished by one of two ways. Either manually editing the main CUI to remove the plug-in ribbon tabs (and panels) from all the workspaces (might as well get rid of the useless Civil 3D Add-ins tab too), then adding back in all the ribbon panels which should now be merging as expected. The easier solution is to just unload all the partial plug-ins CUI files, then restart Civil 3D and all of the plug-ins should load back up merged into the 'correct' Plug-ins tab.
This problem was around in 2012 too and I'm pretty sure I filed a report about it. It's really a straight forward fix so it's a shame it wasn't sorted out before pushing 2013 out the door.
neilyj
Message 8 of 12 (754 Views)
08-15-2012 12:24 AM in reply to: tyronebk
Great catch - this seem to work just fine:smileyhappy:
neilyj
stevenh0616
Message 9 of 12 (599 Views)
01-02-2013 06:59 AM in reply to: StephenMark
Augusto Goncalves had a great post explaining the issue for Civil3D. See this link below:
http://adndevblog.typepad.com/infrastructure/2012/12/duplicated-add-ins-tab-on-civil-3d.html?utm_sou...
Steve
Windows 7 Enterprise 64-bit SP1
Intel Core i7 CPU X920 @ 1.73 GHz
16.00 GB RAM
Civil 3D 2013 - 2015
Check out my AutoCAD, Civil 3D, and Map Apps on the Autodesk Exchange Store at: Autodesk Exchange Store
Active Member
msmith
Message 10 of 12 (450 Views)
05-31-2013 06:35 AM in reply to: stevenh0616
A combination of Augusto & tyronebk's methods yielded perfect results
1. Follow Stevenh/Augusto's post to add the "Civil 3D Add-ins" tab to workspace.
2. Now unload all of the partial cuix's installed by the plug-ins.
3. Restart Civil 3D
Done!
Thanks!
