Civil 3D Forum
AutoCAD crashes when hatch selected
8 REPLIES 8
Message 1 of 9
d_reno
4202 Views, 8 Replies
I am having this problem today using Civil 3D 2011 on a Win7 64 bit machine and closing the properties box doesn't help. Neither does PURGE/AUDIT or RECOVER. I have several solid hatch objects and no matter which one I grab it hangs the software. Anyone have any  other good tips? Punt? Microstation? Jim Beam?
Edited by
Discussion_Admin
David Renaud, RLS
C3D 2012 on 64bit Win 7 all up to date
Dell Precision 7core 8GB RAM
NVIDIA Quadro FX 1800M
LDT/C3D user since release 12
8 REPLIES 8
Message 2 of 9
Jeff_M
in reply to: d_reno
Can you post or email the drawing? miff AT sonic DOT net
Jeff_M, also a frequent Swamper
Message 3 of 9
rkmcswain
in reply to: d_reno
Does it actually crash, or just hang up not responding? If the latter, how long have you waited for it to "come to"?
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 9
gary.lovegrove
in reply to: d_reno
Try moving the hatch origin closer to the hatch objects.
Message 5 of 9
d_reno
in reply to: rkmcswain
Still doing it today. Sigh. I gave it about 20 minutes this last time and finally killed the program to start over on unsaved work. This is the second time I have had to do this in the last half hour. I am so used to grabbing things to change their properties, been doing it for years, that I can't stop myself until it is too late.
David Renaud, RLS
Message 6 of 9
johngordon6189
in reply to: d_reno
assuming your software is up to date with service packs... you can also try using the -purge command to clean up the drawing a bit more (zero length geometry, empty text events, regapps....)
John Gordon
CAD Manager/Survey Technician
C3D 2018/2020
Microstation
Windows 10
Message 7 of 9
grafp
in reply to: d_reno
I had problems using associated hatching on profiles grades. Using C3d entiities as a hatch boundary can really confuse Autocad.
P. Graf
C3D 2009 & 2010
Windows XP
3 GB ram
intel Core 2 Duo
ATI Radeon HD 2400 Pro
Message 8 of 9
d_reno
in reply to: grafp
TURNS OUT i HAD A CORRUPTED PROFILE. demin caps. There were a few other things, like AUDIT taking an extraordinarily long time to finish. I made a new profile and that solved the hatch thing. Thanks for the input.
dr
David Renaud, RLS
Message 9 of 9
mconosciani
in reply to: d_reno
i had this problem before, simply make your hatch scale larger like a 100 or select a hatch types that is not so busy like ansi32. once you adjust the scale/type, the hatch will quickly load and not crash your file. hope this helps
Rail Community
