Member
snake1395
Message 1 of 7 (2,230 Views)
Autocad Civil 3D vs Revit
2230 Views, 6 Replies
12-20-2011 09:18 PM
Hi guys, i've been recently looking at this program: Autodesk Revit, i work with Autocad and Civil 3D, but dont know anything about Revit. My question is: what are the differences between Civil 3d and Revit and if u think that a civil engineer like me should work with Revit too.
Thanks.
Neilw
Message 2 of 7 (2,220 Views)
Re: Autocad Civil 3D vs Revit
12-20-2011 11:06 PM in reply to: snake1395
Revit is Autodesk's Architectural equivalent to Civil 3D. In C3D we have custom civil objects such as surfaces, alignments, profiles, corridors, etc. that dynamically interact with each other and can be edited parametrically. Revit has custom architectural objects such as walls, doors and windows that behave in a similar manner. Insert a door or window into a wall and the wall automatically forms around it. Change the size parameters or move it and everything updates. Delete it and the wall opening "heals" itself.
Civil folks don't typically need such sophisticated architectural tools in their workflows. Usually the buildings are handled by a consultant or another department and the drawings are referenced into the civil drawings for the site design and construction documents.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Distinguished Mentor
michael.robertson
Message 3 of 7 (2,208 Views)
12-21-2011 04:09 AM in reply to: snake1395
Unless you are a bridge engineer I wouldn't really see the need for Revit in the Civil context. Revit does provide bridge extensions for Structural Engineers and the Bridge Modeler labs project allows the flow of bridge data between C3D and Revit.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Member
enrique-evs
Message 4 of 7 (1,873 Views)
10-23-2012 06:00 AM in reply to: snake1395
For Landscape Architects: Revit or Civil3D??
mathewk
Message 5 of 7 (1,862 Views)
10-23-2012 06:50 AM in reply to: snake1395
The answers above pretty much tell you that Revit is not for a Landscape Architect. If you will be importin surveys and making TIN models then Civil 3D, otherwise just AutoCAD.
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
New Member
rodrigo.peraza.castillo
Message 6 of 7 (261 Views)
10-01-2014 03:37 PM in reply to: mathewk
Hy, i currently can't decide, for a water DAM proyect which is the best solution?
Neilw
Message 7 of 7 (257 Views)
10-01-2014 03:52 PM in reply to: rodrigo.peraza.castillo
If it is an earth dam then probably Civil 3D alone could do most of it. If concrete or other structure then you'll likely need Civil 3D for the grading parts and other appropriate tools for designing the structure.
WIN 7 64 PRO
RADEON 6450, 1 GB
