Civil 3D Forum
AutoCAD Civil 3D installation location>\Help\Civil Tutorials\Drawings
4 REPLIES 4
chakwenya
2124 Views, 4 Replies
Good day
Please assist need to access training drawings on my STUDENT CIVIL 3D tutorial drawings folder
<AutoCAD Civil 3D installation location>\Help\Civil Tutorials\Drawings,.The folders are empty when i open them.
 THANK YOU,
PETER CHAKWENYA
4 REPLIES 4
in reply to: chakwenya
Hello
I am a bit novice in the use of application AutoCAD Civil 3D. Could you please assisst me with the above-mentioned
Ekem
mathewkol
Browse to that folder using Windows Explorer and then attach a screen capture here. The files should be there unless you chose not to install them (I'm not even sure this is an option).
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
victormagina17
in reply to: mathewkol
It seems it is an option because i seem not to ever find the folder. is there an online directory from where i can download the entire tutorials folder? please help
samir_rezk
in reply to: victormagina17
Hi @chakwenya
Civil 3D tutorial drawings are usually located at:
C:\Program Files\Autodesk\AutoCAD 20xx\C3D\Help\Civil Tutorials
Here is a link for other important Folder locations, you might need!
Hope this helps,
Samir Rezk
Technical Support Specialist
Rail Community
