Valued Contributor
7 Kudos
Post 11 of 28
Re: AutoCAD Civil 3D ®2013 Service Pack. --> Please tell me one is due out so
09-19-2012 07:43 AM in reply to: gjcbachman
Are you both referring to DText Text Masks? Like with wipe out frames? Or actual Civil 3D object labels that are not appearing correctly?
Paul R. Mascaro
CAD Supervisor | Engineering Design
ENVIRON International Corporation
System: Dell 6800M, OS | MS Windows 7 64-bit SP1, CPU | Intel Core i7 Gen4 @ 3.00GHz Haswell 22nm, RAM | 32.00 GB DDR3 1600 MHz, Graphics | NVIDIA Quadro K5100M (8 Gig), HD | SSD Master, SS Hybrid Secondary
Active Contributor
4 Kudos
Post 12 of 28
09-19-2012 07:48 AM in reply to: pmascaro
I haven't noticed it with Mtext masking just with Civil 3D labels and a custom bubble attribute block that I use in the multileader.  The masking in the C3D label turns a reddish color and the solid hatch that is color 255 in the block turns cyan (the same color as the attribute text).  So far this happens to both in the same drawing.  It only happens to the bubble block in the multileader not if it is inserted into the drawing as a regular block.  I've just started using the multileader in the last couple of months, prior to that I had never had either problem.
Lisa
Windows 7 x 64
Intel i7-4770 CPu @ 3.40 GHz
24 GB RAM
NVIDIA Quadro K2000D
Civil 3D 2015
4 Kudos
Post 13 of 28
09-20-2012 07:02 AM in reply to: pmascaro
I'm having almost all the above issues too.  What happen to the hotfix 2 that was posted?  I did install it, but nothings changed.
Valued Contributor
7 Kudos
Post 14 of 28
09-26-2012 07:52 AM in reply to: sharshbarger
Paul R. Mascaro
Valued Contributor
7 Kudos
Post 15 of 28
10-05-2012 11:54 AM in reply to: pmascaro
1/2 hr to copy and paste some AutoCAD Nodes (Not C3D Points) a few poly lines and some text from 1 drawing to another.
Paul R. Mascaro
Valued Contributor
7 Kudos
Post 16 of 28
11-20-2012 02:22 PM in reply to: pmascaro
Any news???
This is ridiculous that I have to crash out of civil 3D and open map 3d to copy and past or bind an xref....
Grrr....
Paul R. Mascaro
658 Kudos
Post 17 of 28
11-29-2012 11:29 AM in reply to: pmascaro
its out now
you can only get it through the commication center in Civil 3d
attached is the read me
Valued Contributor
7 Kudos
Post 18 of 28
11-29-2012 11:48 AM in reply to: DarrenP
Thanks! Would you mind providing a link? I can't find it anywhere....
Paul R. Mascaro
658 Kudos
Post 19 of 28
11-29-2012 11:49 AM in reply to: pmascaro
read above thread
it hasn't been posted to the autodesk website yet
Valued Contributor
7 Kudos
Post 20 of 28
11-29-2012 11:50 AM in reply to: pmascaro
Nevermind, I found it by logging in through my Civil 3D for a live update.
Paul R. Mascaro
