0 Kudos
Post 1 of 22
AutoCAD Civil 3D 2013 Question
490 Views, 21 Replies
03-18-2013 09:06 AM
I reloaded Civil 3D 2013 to try an resolve some issues I was having with error messages and the program taking for ever to load.  When I first redownloaded the software and installed, it was fine.  Now, two days later, I am having the same problem as before.  I get error messages saying that I am missing shape files and semantic errors in the DCL file.  When the program filanlly opens, about half, if not more, of the widgets in the ribbons are clouds with question marks.  Any suggestions?
264 Kudos
Post 2 of 22
Re: AutoCAD Civil 3D 2013 Question
03-18-2013 10:31 AM in reply to: areawest
Maybe ask in the installation forum.
Credit where credit is due! Give kudos or accept as solution whenever you can.
161 Kudos
Post 3 of 22
03-18-2013 10:42 AM in reply to: areawest
Did you completely remove the previous installation per:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20304823&linkID=9240697
Bill
0 Kudos
Post 4 of 22
03-18-2013 10:51 AM in reply to: wfberry
Bill,
I followed the steps to completely remove 2013, but I did not remove 2010 or LDD.
161 Kudos
Post 5 of 22
03-19-2013 09:43 AM in reply to: areawest
I don't think it is necessary to remove the other products.  However, you may need to run a repair of your installation on the others if you have problems with them.
Bill
0 Kudos
Post 6 of 22
03-19-2013 09:48 AM in reply to: areawest
Bill,
I spoke with a install tech yesterday and they took over my computer and ran the repair.  For some reason, a bunch of the CUI files didn't transfer in the install process.  They got it to work correctly, but when I opened the program today, same issue.  It is driving me nuts.
911 Kudos
Post 7 of 22
03-19-2013 10:11 AM in reply to: areawest
Are you using the correct shortcuts? It sounds like your Support paths are getting reset/removed/not used.
473 Kudos
Post 8 of 22
03-19-2013 10:13 AM in reply to: areawest
Did you allow the new install to "migrate" your files?
0 Kudos
Post 9 of 22
03-19-2013 10:20 AM in reply to: areawest
Jeff and RK,
I used the default settings and didn't change anything.  Looking in the explorer, all the CUI files that were reloaded when the tech repaired Civil 3D yesterday, are gone today?  The only difference between today and yesterday is I turned off my laptop yesterday evening, and back on this morning.
473 Kudos
Post 10 of 22
03-19-2013 10:37 AM in reply to: areawest
There is no default. It will ask you if you want to migrate settings from an earlier version, and you can accept or decline.
