Civil 3D Forum
AutoCAD Civil 3D 2013 PROFILE BAND DOESNT FIT INTO VIEWPORT, PLEASE NEED HELP
6 REPLIES 6
jesseyusufu
1177 Views, 6 Replies
I have created a plan and profile drawing on my sheet but the profile band is out of the viewport. how  can i also align the plan and the  profile   to alight  to the left or how can  i make the plan and  profile to fit inside the  the viewport.
PLEASE SEE  THE PICTURE BELOW
Tags (1)
6 REPLIES 6
GZE
in reply to: jesseyusufu
It happened to me as well. Alignning plan and profile at the center solved my problem
Humphrey GZE
Civil 3D 2013 64bit SP1
Elitebook 8540w
Core i7 2.8GHz, 8Gig RAM
NVIDIA Quadro FX880
160Gb SSD
jesseyusufu
in reply to: GZE
GZE Please how do i align the plan and profile to center so everything fits into the viewport. THANKS
jesseyusufu
i have found the solution after sleepless night. I didnt know that i simply need to create a buffer profile band and that did the margin thank you all
GZE
What is a buffer profile band? Kindly explain
Humphrey GZE
Elitebook 8540w
NVIDIA Quadro FX880
160Gb SSD
jesseyusufu
in reply to: GZE
a buffer profile band is simply a normal profile band that you create with no title band and everything other band property is  set to null except that the title length and width is set so as to provide the necessary space. the picture below shows the result i got
jesseyusufu
Hi all of you civil 3d gurus. my next challenge is how can i separate the profile view height from the viewport. My profile view height as you can see from the photo above is hidden at the top in the viewport. PLEASE I NEED YOUR HELP
Rail Community
