I have created a plan and profile drawing on my sheet but the profile band is out of the viewport. how can i also align the plan and the profile to alight to the left or how can i make the plan and profile to fit inside the the viewport.
PLEASE SEE THE PICTURE BELOW
Solved by jesseyusufu. Go to Solution.
It happened to me as well. Alignning plan and profile at the center solved my problem
GZE Please how do i align the plan and profile to center so everything fits into the viewport. THANKS
i have found the solution after sleepless night. I didnt know that i simply need to create a buffer profile band and that did the margin thank you all
What is a buffer profile band? Kindly explain
a buffer profile band is simply a normal profile band that you create with no title band and everything other band property is set to null except that the title length and width is set so as to provide the necessary space. the picture below shows the result i got
Hi all of you civil 3d gurus. my next challenge is how can i separate the profile view height from the viewport. My profile view height as you can see from the photo above is hidden at the top in the viewport. PLEASE I NEED YOUR HELP
