264 Kudos
Post 81 of 90
Re: Autocad Civil 3d 2013 & Windows 8
03-25-2013 07:16 AM in reply to: AllenJessup
Earlier on this thread, or possibly on one of the other similar ones, a user shared this suggestion: the problem originates with the updated .NET framework that comes with Win8.  The suggestion is to remove the .NET from the machine, and install an older version of .NET. The user then reported no problems in operation.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Member
1 Kudo
Post 82 of 90
03-25-2013 08:26 AM in reply to: troma
Tried that - did not work.
kudos if it works.
343 Kudos
Post 83 of 90
03-26-2013 04:04 AM in reply to: rgraffe
C3D 2014 IS supported under Win 8 http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15444804&linkID=9240697&CMP=OTC-RSS... but Win 7 is recommended
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
911 Kudos
Post 84 of 90
03-26-2013 05:54 AM in reply to: neilyj
Note that it says Windows 8 Professional. So most new pc's that "come with Windows 8" still need to be spec'ed to upgrade to the Pro version.
343 Kudos
Post 85 of 90
03-26-2013 06:07 AM in reply to: Jeff_M
Maybe not sure of the differences but I have Win 7 Home on my laptop and Pro on my desktop and Civil 3D 2013 runs fine on both.
Perhaps it's so you can run compatibilty mode for Win 7..!?!?!?:smileywink:
neilyj
Distinguished Mentor
37 Kudos
Post 86 of 90
03-26-2013 06:31 AM in reply to: neilyj
Regular Windows 8 should probably work fine, the main difference between regular and pro editions are enterprise type capabilities such as:
Remote desktop connections
the ability to participate in a Windows Domain
Encrypting File System
Hyper-V (virtualization)
Virtual Hard Disk (VHD) booting
Group policy
Bitlocker & Bitlocker-to-go
For full version comparison see Wikipedia: http://en.wikipedia.org/wiki/Windows_8_editions
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Active Member
1 Kudo
Post 87 of 90
04-11-2013 07:13 AM in reply to: michael.robertson
Hot Fix 3 appears to have resolved the Windows 8 issues.
I have been running since yesterday.
Anyone else seeing positive results?
Active Member
1 Kudo
Post 88 of 90
04-11-2013 08:04 AM in reply to: kra1366
downloaded and tried it -
anything in 2d works (did before) but still crashes when editing Civil 3d modules.
could be because everything here is networked to a server.
Valued Contributor
1 Kudo
Post 89 of 90
04-11-2013 04:55 PM in reply to: rgraffe
I was able to work with sections that caused it to crash before.
Yeah!!!!
0 Kudos
Post 90 of 90
04-12-2013 10:00 AM in reply to: troma
Yes! I'm up and running now with no major crashes. I say 'major' because, now, I receive an error regarding the .Net framework but it doesn't crash. C3D just errors and allows me to continue. I haven't tried all functions yet, so it's early... I was crashing roughly 10 seconds into working in any drawing.
Civil 3D 2013
Dell Precision T7500, Windows 7, 64bit Pro
Xeon proc., 2 @ 2.13GHz
24GB RAM
