I would like to post the probleme autocad civil 3d and windows, i try to install it but during the installation wizard "framework 4" the process stopped and the installation wizard crash
can anyone post a solution for this problem
Solved by Jeff_M. Go to Solution.
After I installed Service Pack 1 my crashing issues went away.
I also installed Start8 to bring a start menu back.
I really prefer 8 to 7 now.
I'm running C3D 2013 SP1 on Win 8 with no major issues (so far). My computer is a 5+ year-old Core 2 Duo 6400 with 2GB of RAM, and Windows 8 (32 bit) and Civil 3D both run great. I upgraded from XP, so going to Win 7 is not really an option. I've been running Win 8 since September, and upgraded to the final version the day it was released. Windows 8 boots up and runs significantly faster than XP ever did on this machine. No way would I go back to XP. BTW, I second the recommendation for Start 8. Best five bucks I've spent in a long time.
Widows 8 x64 + Civil 3D 2012 = no work.
As long as I am using it as AutoCAD, it works fine.
As soon as I start thinking about creating an alignment, crash. Haven't tried anything else.
Then I discovered this topic, so at least I am not thinking about smashing my compiter anymore
Btw, my system is:
AMD A10-4600M with Radeon HD Graphics @ 2.30 GHz
8 GB of RAM
x64 Windows 8
Very dissapointed.
I saw one guy mentioning C 3D 2013 working good on Win 8.
Anybody else with positive experience on that?
autodesk never said civil 3d was compatible with windows 8
DarrenP
As this thread has pretty much pointed out:
C3D 2012 & Win8 = not stable & no support
C3D 2013 w/o SP1 & Win8 = iffy & no support (some seem to not be having a problem)
C3D 2013 w/ SP1 & Win8 = works & no support
I've found that the most issues I have with windows 8 and C3D 2013 is working with profiles & pipe networks.
Luckily if I'm going to be worikng on profiles I reboot to a different HD with win 7 loaded.
I've got the same pbromlems. Autodesk Civil 3D 2013 (on Windows 😎 is working normally like Autocad. But doesn't work at all with Alignmen, Surfaces etc...
And I think there is only one solution for this problem - uninstalling Windows 8.
Sad but...
This topic has been discussed ad nauseum - but to reiterate: at this time no version of Civil 3D IS SUPPORTED UNDER WINDOWS 8
Can we please draw a line under this topic now......
I got it, Windows 8 isn't supported nowadays, but my question is... does anybody know when it's going to be supported? I need this program to an University's subject... so I need it quickly.
But I can't understand why it works in some computers and doesn't works in others. What does it depends?
I have no problems on Windows 8 with the majority of what I do.
Profiles, Pipe Networks, Sections are where my problems occur.
I just reboot to a secondary HD with win 7 installed any time I
have to do the above.
HTH
Robert
Edit: Profiles work ok. Just did some last night
My civil3d has been crashing with win8 after 45secs-1:00min from start-up with a drawing of a file size about 880kb. However, I have found a strange way of fixing it and was very coincidental. All I did was open the properties of a point in my drawing. I am positive this stops my civil3d from crashing but here is a list of other things I have done...
PROGRAM COMPATIBILITY SET TO WINDOWS 7 IN PROPERTIES WHEN RIGHT CLICKING ON THE ICON
THEN
SET USER ACCOUNTS ACCESS OFF(BAR ALL THE WAY DOWN)
DO NOT CLOSE WELCOME SCREEN (WAIT FOR THE WELCOME SCREEN TO BE SETTLED ABOUT A FEW MINS???)
KEPT PROPERTIES IN CIVIL3D OPENED AT ALL TIMES
ALSO MADE CREATE POINTS BAR PINNED
Forgive my ignorance, but which SP1 are you saying about? AutoCAD Civil 3D 2013 Service Pack 1? I've read what was written about this SP1 it but there's nothing about it supports Win 8.
I did everything you've recommended and I installed AutoCAD Civil 3D 2013 Service Pack 1.
I don't know which one helped may be both. But I've tryed few simple things and it's working!
I want to thank everyone for the help
hello i see ur problem in the program civil 3d
did u find any solution for this problem please reply me quickly coz i have the same problem and iam soo disapointed :S
Search the group. there have been may posts on this subject including today. Why are you disappointed? Because a program that isn't supported under Windows 8 doesn't run well on it. That should have pretty much been expected.
Don't by hardware or an OS and hope your programs will run on it. Buy what you know will run the programs that are important to you.
Allen Jessup
Civil 3D 2012 SP 2.1
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
i do this steps but what is the solution for make my program run and faster ??
Buy a FAST computer. Install a SSD as your main drive.
I just built a cad station for $600 with a i5 3570, 8 GB Ram, 120gb SSD and ON-BOARD intell HD 4000 graphics.
Runs 2 monitors great. All I her from the 2 tech's that use it is that it is smoother than any of the other pc's.
Bo
my lab specs is
8 GB of RAM
x64 Windows 8
nd it's still slowly nd bad :S
Could we stop with all the Windows 8/Civil 3D posts?
It may or may not work and is not supported.
If people want to talk computers specs start a new thread please.
