Active Member
fayoud
Message 11 of 90 (3,071 Views)
Re: Autocad Civil 3d 2013 & Windows 8
10-09-2012 08:36 AM in reply to: michael.robertson
Bonjour, mais cette méthode ça marche pas
merci
Oudjhih Fayçal
Active Member
kra1366
Message 12 of 90 (2,910 Views)
10-29-2012 11:22 AM in reply to: fayoud
Any one having issues with the final release of Windows 8 and Autocad Civil 3d 2013?
Everything works well, couple of minutes having the program running, the program crashes.
Tried different drawings, no luck.
Installed "Hotfix 2" no luck
Running with 64bit and as the administrator.
neilyj
Message 13 of 90 (2,897 Views)
10-29-2012 11:33 AM in reply to: fayoud
it's still an unsupported OS so problems will be inevitable
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Valued Contributor
bo.martin
Message 14 of 90 (2,892 Views)
10-29-2012 12:25 PM in reply to: kra1366
Being running 2013 on Win 8 Final Release (RTM) for over a month.
I did have a crashing problem and it ended up being the drawing.
Other than that no issues.
Have you updated your video drivers from your MFG web site?
All updates to win 8 installed?
Here is my system
Gigabyte MB, i5 3570 CPU, 8 Gb Ram
Corsair SSD Boot, 1TB WD Data Drive
AMD 6850 GPU (Not certified) (I play games)
Dual 24" Monitors
At work we have AMD V3900's for the GPU
Great $120 video card. Solved quite a few issues with 2013.
Haven't tried it on 8 yet.
Good Luck
Active Member
kra1366
Message 15 of 90 (2,879 Views)
10-29-2012 01:01 PM in reply to: bo.martin
Thanks for your responce.
Updated the vidieo card drivers
I installed all the current Windows updates.
Installed the Autocad hotfix 2 .
I just re-installed Autocad. No luck
I tried another drawings, does not seem to make a differance.
Sony laptop, Core I7 Processor
8gb ram
256 gb Sandisk Extreme SSD
Suggestions?
Back to Windows 7?
Valued Contributor
bo.martin
Message 16 of 90 (2,782 Views)
11-01-2012 03:58 PM in reply to: kra1366
Well it seems that windows 8 doesn't like cross sections.
It crashes when I try to work with sections. On my win 7 system
same dwg works fine.
Argh!! I'm really liking win 8 too.
Bo
neilyj
Message 17 of 90 (2,765 Views)
11-02-2012 01:16 AM in reply to: fayoud
AutoCAD + Civil 3d + Windows 8 = User Beware
neilyj
New Member
anthonyad
Message 18 of 90 (2,699 Views)
11-04-2012 06:16 AM in reply to: fayoud
i have Autocad Civil 3D Land Desktop Comapnion 2009
and i would like to install windows 8
if i install it, will the application stay working after the switch or will i need to reinstall autocad?
neilyj
Message 19 of 90 (2,689 Views)
11-04-2012 08:16 AM in reply to: anthonyad
Refer to previous posts - Windows 8 remains unsupported and Autodesk software may or may not work - I'd suggest it may not be worth the hassle in a production environment at this time
neilyj
Valued Contributor
bo.martin
Message 20 of 90 (2,665 Views)
11-04-2012 04:52 PM in reply to: anthonyad
Buy a new hard drive, do a clean install to it.
I'm going to buy anothe SSD so I can boot into
win 7 if I have to do crosections.
If it's your only hardirive I'd say no to windows 8 if
you need to use autocad.
Bo
