Civil 3D Forum
Autocad Civil 3d 2013 & Windows 8
89 REPLIES 89
Message 1 of 90
fayoud
16744 Views, 89 Replies
I would like to post the probleme autocad civil 3d and windows, i try to install it but during the installation wizard "framework 4" the process stopped and the installation wizard crash
can anyone post a solution for this problem
Oudjhih Fayçal
89 REPLIES 89
Message 2 of 90
antoniovinci
in reply to: fayoud
Windows.. what?? How did you get that?
Don't be surprised if something's going wrong on a beta OS, sir...
Message 3 of 90
neilyj666
in reply to: fayoud
Windows 8 is not supported by any Autodesk products mainly because it is, as Antonio pointed out, still essentially a beta OS.
Undoubtedly, the Autodesk product family will run under Windows 8 at some point in the future but until then you are on your own....
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 4 of 90
michael.robertson
in reply to: fayoud
Windows 8 is no longer Beta, the RTM version is available to certain people (MSDN members for example).
Although I had no problem installing C3D 2013 on Win8 I did have the same problem you are having with installing C3D 2012.
Here's what I had to do.
Copy all the installer files from the DVD onto my local harddrive.
Install .NET 2.0 from MS website
Open the "Setup.ini" file at the root of the DVD content
Delete section from #============= DOTNET Begin =============== to #============= DOTNET End ===============
Save Setup.ini file
Run Setup.exe
As a side note, i've run into problems on Win8 installing various programs that try to install various versions of the Microsoft Visual C++ 20XX SP1 Redistributable. When this happens I've been able to fix the problem by downloading and installing the redistributable straight from Microsoft then reinstalling the problem program.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Message 5 of 90
Beta or RTM version - makes no difference, still not an officially supported OSSmiley Happy
Whilst you are to be applauded for your workaround, i'd suggestt that is a bit much to expect an "ordinary Joe" to be able to know what to do.
I'd guess the 2013 product family are pretty much Windows 8 ready but as for previous versions........Smiley Frustrated
Message 6 of 90
michael.robertson
in reply to: fayoud
Not supported, true, will be used any way, I'm sure.
Put it out there for IT or Developer types that have to test before Win8 is released to the general public.
Mike Robertson
Message 7 of 90
fayoud
in reply to: antoniovinci
Message 8 of 90
antoniovinci
in reply to: fayoud
Merci, monsieur Fayoud (vous parlez italien aussi, n'est-ce pas..?)
Message 9 of 90
in reply to: fayoud
I've had C3D running on 8 RTM since day 1 of the release.
It isntalled fine. Make sure all user access control is turned off.
FYI...
Windows 8 boots faster, resumes from sleep faster, has better dual monitor support
You just have to look as the new interface as you start menu instead of go WTF is this 🙂
Once your to the desktop it's practicly the same (sans the Start Menu)
If you need a start menu install Start8 from stardock.
Message 10 of 90
michael.robertson
I too had no problem getting 2013 on Win8, I did have a problem with 2012 though where the work around I noted fixed it.
I agree with you on the Win8, once you realize you have a start screen instead of menu there really is no huge differences except a faster more secure machine. Everyone talks about the interface but there is a lot of behind the scenes changes that were made that make it faster and more secure.
Mike Robertson
Message 11 of 90
fayoud
in reply to: michael.robertson
Bonjour, mais cette méthode ça marche pas
merci
Oudjhih Fayçal
Message 12 of 90
in reply to: fayoud
Any one having issues with the final release of Windows 8 and Autocad Civil 3d 2013?
Everything works well, couple of minutes having the program running, the program crashes.
Tried different drawings, no luck.
Installed "Hotfix 2" no luck
Running with 64bit and as the administrator.
Message 13 of 90
neilyj666
in reply to: fayoud
it's still an unsupported OS so problems will be inevitable
Message 14 of 90
Being running 2013 on Win 8 Final Release (RTM) for over a month.
I did have a crashing problem and it ended up being the drawing.
Other than that no issues.
Have you updated your video drivers from your MFG web site?
All updates to win 8 installed?
Here is my system
Gigabyte MB, i5 3570 CPU, 8 Gb Ram
Corsair SSD Boot, 1TB WD Data Drive
AMD 6850 GPU (Not certified) (I play games)
Dual 24" Monitors
At work we have AMD V3900's for the GPU
Great $120 video card. Solved quite a few issues with 2013.
Haven't tried it on 8 yet.
Good Luck
Message 15 of 90
Thanks for your responce.
Updated the vidieo card drivers
I installed all the current Windows updates.
Installed the Autocad hotfix 2 .
I just re-installed Autocad. No luck
I tried another drawings, does not seem to make a differance.
Sony laptop, Core I7 Processor
8gb ram
256 gb Sandisk Extreme SSD
Suggestions?
Back to Windows 7?
Message 16 of 90
Well it seems that windows 8 doesn't like cross sections.
It crashes when I try to work with sections. On my win 7 system
same dwg works fine.
Argh!! I'm really liking win 8 too.
Bo
Message 17 of 90
neilyj666
in reply to: fayoud
AutoCAD + Civil 3d + Windows 8 = User Beware
Message 18 of 90
in reply to: fayoud
i have Autocad Civil 3D Land Desktop Comapnion 2009
and i would like to install windows 8
if i install it, will the application stay working after the switch or will i need to reinstall autocad?
Message 19 of 90
neilyj666
Refer to previous posts - Windows 8 remains unsupported and Autodesk software may or may not work - I'd suggest it may not be worth the hassle in a production environment at this time
Message 20 of 90
Buy a new hard drive, do a clean install to it.
I'm going to buy anothe SSD so I can boot into
win 7 if I have to do crosections.
If it's your only hardirive I'd say no to windows 8 if
you need to use autocad.
Bo
Rail Community
