Civil 3D Forum
autocad civil 3d 2012
2 REPLIES 2
rohitverma21
308 Views, 2 Replies
dear sir
           i have autocad civil 3d 2012,  i have facing some problem with that i found only 4 option in that version civl 3d, 2d and 3d anotation, and planning and analysis, i think missing option tool base geospecial and task geoption, before i was using autocad civil 3d 2011 having all option, its my autocad civil 3d 2012 incomplet please give me solution write rohitverma21@gmail.com
please dear al sir replyme
2 REPLIES 2
AllenJessup
in reply to: rohitverma21
You're not missing anything in 2012. At least in Autodesk's mind, Planning & Analysis replaced the other Map based ribbons.
Allen
Allen Jessup
CAD Manager - Designer
LeafRiders
in reply to: AllenJessup
Unfortunately Autodesk doesn't think like a hands on user sometimes. I keep my Menu Bar showing and I add in "Map" to gain access to additional Map 3D features that should be readily available in Civil 3D. What you should to do is pick one that's close and customize your workspace as you need it. Save your workspace setting and use that instead of what Civil 3D out of the box gives you. Everything you had access to before is there, except now you have to into your "CUI" and transfer over your mapping tools into your Civil 3D environment.
Rail Community
