I'm getting ready to install AutoCAD Civil 3D on my computer and I like using the AutoCAD classic toolbars instead of the newer ribbon. Does AutoCAD 2012 still have the classic toolbar that you can switch to?
Thank you.
Why not just use the "menubar" in addition to the Ribbon. You will miss out on commands that are only available in the Ribbon.
Bill
Fully agree, if you are not using the ribbon you will miss out on newer C3D commands (unless you somehow memorize every C3D command).
If you don't like the screen space of the ribbon it can be minimized where it takes up the same amount of room as a menu.
It does. But as the others did I recommend you leave the Ribbon open but minimizes. I was never a fan and get around it by creating ToolPaletts for different tasks. You can add any Civil 3D command you want to a ToolPalette.
The thing I do like about the Ribbon is that it is context sensitive. That means that if you select a Civil 3D object. It will automatically open a Ribbon tab with object specific commands. If you select a Featureline the tab will contain command specific to Featurelines. Likewise Surfaces, Corridors, Profiles etc.
Allen
Allen Jessup
CAD Manager - Designer
If I understand your original question you are looking to add the toolbars but not replace the ribbons. On the View tab, at the far right hand end, is a toolbar button. First click toolbar, then choose the category and the specific toolbar to turn on. You can place them where ever you wish.
Continue to use the Ribbon for new commands you may find that it is easier to use than some of the toolbars.
I'm with you. A person has certain tools that he uses all of the time. These tools take up the same space or less space than the ribbon. The ribbon often requires the operator to "click" three times to execute a command whereas the toolbar requires just one click. With Civil 3D 2013, practices are going back to toolbars. 🙂
I like to put the commands I use most on Toolpaletts, divided up by task.
Allen
Allen Jessup
The key to the Ribbon is its contextual nature. In the past the menu system has been verb - noun, where you find the command and the pick the object that you want to use that command on. If you work this way, then the ribbon is just a big tool bar that you have to wade through to find you commands.
But that's not how it is designed to work. If you select the object first the ribbon will change and present the commands that you can do on that object. For me this is the beauty of the ribbon. I never have learned where any of the commands are in the ribbon, because I know that after I select an object and look up at the ribbon, the commands that I need will be waiting for me.
Peter Funk
Autodesk, Inc.
Thanks for the comments Peter. I wish the bug described below would get fixed in the first SP for 2013 though. It currently makes the contextual ribbon a pain to use. Why would getting something simple like this be shelved until the next release?
http://cadpanacea.com/node/373
Other than civil3d commands what tool bars do you miss so much?
Your Name
Your Name
I always like how the replies hardly ever answer the questions asked. It is always, you should do it this way or you should do it that way, never if this is the way you want it, then you set it up this way. Just saying......
You resurrect an eight-month-old discussion to complain about it?
Besides, the answer is there: yes, the toolbars are available but they only contain the same commands as always. New commands are only on the ribbon by default. Other suggestions and recommendations were not out of place.
Mark Green
Working on Civil 3D in Canada
Mark Green
Troma,
There was no relation between my response and any other post. I wasn't trying to get that funny. I'm too busy with another man down in the office to dedicate any short term memory on this NG. 😉
John Mayo
The OP got his answer fast and recommendations for best practices. Kudos to all in my book. 🙂
John Mayo
