My auto linework displays as blue lines with little magenta circles on the ends of the lines. the lines are drwan on the right layer. is there a way to make them display according to the layer they're on and without the circles?
Solved by Jay_B. Go to Solution.
Is the proper Figure Prefix Database being used? If you have one set up I'd first check that.
Otherwise the linework display is controlled by the Figure Style in use which if you were to change the layer within the figure style being used to zero it will take on the layer symbology similar to the way blocks work.
To turn off the markers go to the Display tab within the style and for the plan view direction, turn off all that say "Marker" and leave "Figure Lines" on.
