Active Contributor
mikerobe100
Message 1 of 5 (179 Views)
Auto Linework Draws some, not others
179 Views, 4 Replies
01-14-2014 04:58 AM
I located a sidewalk next to a curb line. i coded them the same way. when i import the points my sidewalk auto draws but my curb line does not. i have another curb line that I didn't even code for autolinework and it draws. the curb I want drawn is BC the other curb that autodraws is coded BC1. any ideas?
If your using BC and the linework code set has the linework code for a begin curve as BC that's is you problem, change the linework codeset to PC & PT for the begin and end curve, and all should work. OOTB these codes are set as BC & EC, so if you description macthes these, that is the problem.
Edited to add image
Distinguished Mentor
rl_jackson
Message 2 of 5 (178 Views)
Re: Auto Linework Draws some, not others
01-14-2014 05:04 AM in reply to: mikerobe100
Edited to add image
C3D12-13
Win7x64 6gb
Active Contributor
mikerobe100
Message 3 of 5 (166 Views)
01-14-2014 05:29 AM in reply to: rl_jackson
I'm using BL for begin, EL for end and OC for on curve. Here is a screen shot.
Active Contributor
mikerobe100
Message 4 of 5 (161 Views)
01-14-2014 05:34 AM in reply to: mikerobe100
You were correct. I had BC for begin curve. I changed it to PC and now it works. Thanks.
rl_jackson
Message 5 of 5 (159 Views)
01-14-2014 05:35 AM in reply to: mikerobe100
Yes, but when you use the BL you should be using the linework code for your begin curve instead, since you using OC you telling it to start a curve, where BL is but BL is being used to start a Line not a curve, see the edit to my previous message. There will be issues with using BC as back of curb, and BC as begin curve
C3D12-13
Win7x64 6gb
