Civil 3D Forum
auto-hatch survey figures
3 REPLIES 3
balloonsrise
890 Views, 3 Replies
Is there a way to have certain figures auto-hatch upon import?
Civil 3D 2013
Windows 7 64-bit
Inteel 2.40 GHz 8 GB RAM
Dell T7600
3 REPLIES 3
You can set up the figure prefix database so that figures with certain names will be defined as lot lines.   When importing into the drawing, lot lines that form closed areas will define parcels.
Set the default parcel style to have the parcel area fill component visible.   You may also need to clear the Observe fill distance option on the Parcel Style Design tab.
David Zavislan, P.E. | Wood Rodgers, Inc.
in reply to: david.zavislan
That's good. But it would be better if it could apply a fill style based on the particular figure style or apply a particular parcel style to a point code from the figure prefix database.
EG. different fills for ponds, buildings, vegetation, swamp etc.
A wish list item I suppose? 12D can do it.
Cheers
How do you set a default parcel style when choosing a Site in the Figure Prefix Database?
By default the figure prefix database lot always goes to "Survey Site"
I want to hatch a concrete slab in ACAD and made a parcel style and Site called "CSLAB".
When I process the line work the "Standard" Parcel style is chosen rather the "CSLAB" parcel style (even though I choose CSLAB site in the figure prefix database also ).
Rail Community
