Civil 3D Forum
Attributed Block Glitch?
10 REPLIES 10
Message 1 of 11
gccdaemon
394 Views, 10 Replies
I inserted an attributed block into a drawing with another attributed block. What i was trying to accomplish (and have done in previous versions) is use the BLOCKREPLACE command to swap out the old block for my symbol, then ATTSYNC the replaced blocks and set the attribute on them globally using SELECT SIMILAR. The problem i'm getting now is that after i ATTSYNC the block it's rejecting any input in the properties palette. The attribute inside the block does have a preset value, and after changing it in the block editor and re-attsync, it still doesn't update. Can anyone replicate this in C3D 2013 x64?
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
10 REPLIES 10
Message 2 of 11
in reply to: gccdaemon
I usually just use the -insert command to replace old blocks with new ones. it will keep all attribute data associated with the block.
Message 3 of 11
gccdaemon
Yes but with a survey files with hundreds of blocks like this, that would be very time consuming.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 4 of 11
you could use action recorder and set up a macro or a short lisp routine
Message 5 of 11
gccdaemon
The purpose of this is to see if anyone can replicate the problem so i can figgure out if it's just me or if a bug report needs to be filled out.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 6 of 11
Joe-Bouza
...but thanks for trying to help...
Joe Bouza
Message 7 of 11
Neilw_05
Could you post your two blocks for testing?
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 8 of 11
gccdaemon
The original file appears to have been made with Land Desktop. My blocks are on the E-UTIL-APP layer and the originals are located on their own independant layers. I was able to get a work around by inserting my blocks inside theirs and exploding, but like I mentioned before this is purely for testing. I'm also curious if this happens with blocks made in 2013 as well. I havn't had time to test it out yet being the buisy time of year and all.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 9 of 11
Neilw_05
I can confirm the behavior. The attribute of the replaced blocks cannot be edited in the properties pallet. If you make copies of the replaced block, they behave normally.
I don't have an explanation as to what causes this.
WIN 10 64 PRO
Message 10 of 11
gccdaemon
I think it may be corrupted block information created by LDD. I tested it out on some older blocks not done in LDD and it seems to work just fine. I guess we'll just chock it up to compatibility problems. Thanks for the assistance guys.
Andrew Ingram
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
Message 11 of 11
Neilw_05
I suggest you submit the issue to support. They may not be aware of the behavior.
WIN 10 64 PRO
Rail Community
