Civil 3D Forum
Associatin​g Drawing to Project Error
4 REPLIES 4
craigswearingen
463 Views, 4 Replies
I have created a new data shortcut project folder, i have the data shortcut set to the drive & the correct project, yet i cannot associate the drawing to the project.  Even when I do attempt to set it to the correct project, it will not register.  I have tried the "associate current dwg to project", as well as the "associate multiple dwgs to project", yet it will not recognize it at the top of the screen.  Anyone else having that issue and have you found a resolution? Thank you
"There's always room."
Windows 10 Professional
64-Bit Intel Xeon W-2125 @ 4.00GHz
AutoCAD Civil 3D 2018.3
4 REPLIES 4
Jay_B
in reply to: craigswearingen
Right click on Data Shortcuts>Set Data Shortcuts Project Folder>
Is 5330 specified?
Also what is the full path of drawing 5330_441.dwg and under what folder is _shortcuts folder?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
craigswearingen
in reply to: Jay_B
U:\5330\ProjDevelopment\Design\Drawings
It seems to only be this project.  Because it recognizes the project, data shortcut, and project association with other jobs on the same server, in the same directory.
Noticed that the design team had began another project inside the project, therefore my project association wasnt recognized due to the pathing and i had to dig a bit deeper into the project folder to find a recognizable association.  Thank you.
Jay_B
No problem, glad you figured it out, it was my suspicion it had to do with mapping but it's very difficult to follow when the setup can't be seen. Smiley Wink
C3D 2018.1
C3D 2016 SP4
Rail Community
