I am designing a roundabout using Stockdale method. I am now vertically designing the crown lines of each arm and circulatory carriageway.
While designing the vertical profiles of one of the crown line I like see the gradient and levels of the other alignment in this profile where it ties in to. Is it possible to associate the vertical pofile of a different alignment in to this so that i can match the gradient and level in the crown line profile. I attach the Plan view of the crown line and other alignment.
Solved by Jay_B. Go to Solution.
If your asking if 2 separate Layout profiles which each belong to separate alignments, can be shown in the same profile view?,
then take a look at the _AeccSuperimposeProfile command.
This command will overlay (superimpose) a secondary crown profile onto the primary crown profile view belonging to the primary
alignment.
Help for Creating a Superimposed Profile
