<68widetrack> wrote in messageThis
href="news:6046526@discussion.autodesk.com">news:6046526@discussion.autodesk.com...
pops up in c3d as a ? dialogue box, this is a new one to me. options are Yes
or No,
"68widetrack" wrote in messageThis
or No,
"68widetrack" wrote in messageJeff,
href="news:6046593@discussion.autodesk.com">news:6046593@discussion.autodesk.com...
I am unsure what to remove or how to comment out? I'm not sure where the "Make
Object Layer Current" section ends, or how to "comment out". Can you show me
in the attached notepad file? Thanks David
@Anonymous wrote:
This is a BUG that Autodesk should have fixed a
LOOOOONNNNNGGGGG time ago. It comes from the fact that the old layers portion of
Express Tools have been incorporated into the base Autocad, but the Menus are
still loading the Lisp version of the Make Object Layer Current command. It only
shows it's ugly face when you have opend the VLIDE and the option to "SETQ to
protected symbol" is set to anything other than Transparent.
I realize this thread is a few days old but I just had this happen in 2014 after opening VLIDE.
It locked up my session which had 3 dwg's open and after an End Task things seem normal for now .
Still getting in 2014. I switched to the 'generic' autoCAD work station and it comes up when I open a new file.
I will try exiting and coming back in.
I hit yes and it doesn't seem to bother anything other than the time lost.
So let's say, hypothetically, that this hasn't been fixed in the 2016 version, and that editing the civil.mnl file appears to be prohibited. How might one go about addressing this issue?
@ArloCAD wrote:So let's say, hypothetically, that this hasn't been fixed in the 2016 version, and that editing the civil.mnl file appears to be prohibited. How might one go about addressing this issue?
If you type (findfile "Civil.mnl") at the command line you can locate the file in question.
You should get something like this "C:\\Users\\YourName\\appdata\\roaming\\autodesk\\c3d 2016\\enu\\support\\Civil.mnl"
I copied this civil.mnl file on to my desktop and made the appropriate changes as mentiond above.
I renamed the original file to "Civil-OLD.mnl"and then copied the amended file in to replace it.
I faced this issue and it caused my surface style to change from slope banding to colored triangles!
I removed the command as Jeff siad, replaced the file, closed and reopen C3D and it worked.
Hi. I am running Autocad Civil 3D 2016 and am having the same problem. I have renamed the function as you have described in both the Civil.MDL and c3d.MDL, and the problem still persists?
Found the SETQ options in VLIDE---TOOLS--ENVIRONMENT OPTIONS-- GENERAL.
Set it to Transparent and it seems to have worked in eliminating that prompt.
Autocad2016
Thank you. This seemed to have worked and is a lot simpler than trying to edit the MNL file as suggested by the other answers.
Still an issue with 2022, but was corrected with changing the transparency setting that @e.aguilera suggested.
