If I have a drawing scale set up as 1"=30' and I created some profiles at that scale, and then I need to create a profile at 1"=40' horiz and 1"=4' vert., what is the best way to do that? I believe in the past I tried changing the drawing scale under settings to 1"=40' one time and all of the profiles in the drawing changed to that same scale even though they were drawn at 1"=30', which I want to stay that way. I think I can leave the drawing settings to 1"=30 and then just assign the scale in the viewport to 1"=40', but then all of the text sizes in the profile view style will adjust according to the scale I use, which will either increase or decrease according to the scale I pick. I would like to keep the profile view style consistentno matter what scle I pick...thanks
Solved by dgordon. Go to Solution.
The scales of your profiles are controlled by your profile style. So it you want to have a profile 1"=40' you would have to have The profile style set to 1"=40'
So I never have to adjust the drawing setting scale? It can remain at 1"=30' If the profile is at the correct scale in model space all I have to just adjust it in the vewport at approp scale and then maybe make a new profile view style to accomoddate to the new scales?
