Civil 3D Forum
Assign feature line elevations from points
19 REPLIES 19
Message 1 of 20
rkmcswain
1360 Views, 19 Replies
Given a feature line/polyline(FL/PL) and a series of points directly on the FL/PL, how can you assign the elevations of the points to the vertices of the FL/PL?
Without using a surface?
19 REPLIES 19
Message 2 of 20
troma
in reply to: rkmcswain
How automated are you looking for?
Coz I would say you could use the 'Insert Elevation Point' and snap to the cogo points one by one, given that they're displayed at their elevation.
Mark Green
Working on Civil 3D in Canada
Message 3 of 20
troma
Or draw a new feature line using 'PN
Mark Green
Message 4 of 20
mathewkol
Or the 'PO transparent command so you don't have to enter numbers.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 5 of 20
rkmcswain
in reply to: troma
Like this automated.
I was pretty sure this didn't exist in C3D, but was hoping I was wrong
Message 6 of 20
MikeEvansUK
The easiest solution I know of without aditional tools is to export the points in xyz format to a text document.
Now Add the following lines above the first entry.
3dpoly
E,N,Z
E,N,Z etc.
(Add return below last value to end command)
Save and rename to Scr file the in Civil3d run Script, load the file and it will draw the 3dpolyline from the points.
Convert to featureline and use normally.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 7 of 20
AllenJessup
It's interesting. I have 2 3rd party softwares and neither will do this that I can see. It looks like Toolpac [that I don't have] will do it.
Allen
Allen Jessup
CAD Manager - Designer
Message 8 of 20
Jeff_M
in reply to: AllenJessup
Allen
Never needed it and never had a customer ask for it. Interestingly, the last thing Sinc asked me to add before he fell ill was a command to elevate featurelines from text/mtext (think non-C3D grading plans obtained from other engineers). It is complete but was not added to the help file or published command list. When I saw this thread I figured it would be easy enough to include points in the search for nearby objects. So I will be working on that soon.
Message 9 of 20
AllenJessup
in reply to: Jeff_M
Neat!
Allen Jessup
Message 10 of 20
TerryDotson
The 2D-3D by Points in MapWorks Base has done this for a long time, working directly with FeatureLine and AeccPoint objects.
Message 11 of 20
MikeEvansUK
I do actually have a program i wrote which will create a 3d polyline from text, blocks, point, in fact I think anything so long as it has a single xyz position. I could add feature line to it with ease. Funny thing is that when I debug it works fine but throws an error immediately. Something I need to resolve, it's to do with the selection set method. I'll post the code if anyone would like to help fix it and promise to keep it a freeware package.
Mike Evans
Message 12 of 20
rkmcswain
Thanks for all the replies. I'm going to find out if this was a one time need or something we'll need regularly in the future, then make a decision about how to proceed.
Message 13 of 20
Joe-Bouza
Proximity fault with the check convert to standard?
Your Name
Message 14 of 20
AllenJessup
in reply to: Joe-Bouza
Joe, That would seem to require a Surface.
Allen
Allen Jessup
Message 15 of 20
jmayo-EE
A one click command would be real nice but if they don't open the wallet (for one of those fine products listed above 🙂 ) I would just make the surface anyway. Then use ElvFromSurf on the Fline. Multiple FLines could be done in seconds.
John Mayo
Message 16 of 20
Joe-Bouza
Correct, but its not too difficult to make a surface of the said points. Strictly OOTB
Your Name
Message 17 of 20
AllenJessup
in reply to: jmayo-EE
I would also. But the OP requested how to do it without a surface. So I took that as meaning he already knew how to do it with a surface.
Allen
Allen Jessup
Message 18 of 20
AllenJessup
I know. But the OP wanted not to create a surface. See my response to John.
Allen
Allen Jessup
Message 19 of 20
rkmcswain
@Joe-Bouza wrote:
Correct, but its not too difficult to make a surface of the said points....
Just to clarify, I said "without using a surface" in the original post because we are aware of that method. Not that we are opposed to it or anything, I was just trying to proactively weed out the "use a surface" replies and see if there was more of a one step method.
Thanks again.
Message 20 of 20
jmayo-EE
I think we all understand that. Digging into the procedures and exploring alternatives can save a lot of time.
John Mayo
Rail Community
