Civil 3D Forum
Assign/Change Alignment Label Style Set
5 REPLIES 5
Jason__M
3961 Views, 5 Replies
Using Civil 3d2012, Is it possible to change the alignment label style set after the alignment has been created?  For example, for an alignment that was created with alignment label set X - change the label set to alignment label set Y?  It seems like this should be pretty easy, I must be missing something obvious.  Thank you.
5 REPLIES 5
Jeff_M
in reply to: Jason__M
Yes. Select the alignment, right-clcik, choose Edit Alignment Labels, at thhe lower right of the dialog click the Import Label Set button, select the correct set. The new set will replace the original.
Jason__M
in reply to: Jeff_M
You're quick!  Thank you.
ronpemberton7479
in reply to: Jeff_M
I tried this solution but when I right click I just get the standard shortcut menu, no option for "edit alignment labels".
Is there a direct command for this?
Until about a week or so ago I have always been able to right click on any Civil 3D object and go directly to its properties or styles. Now I only get the standard shortcut menu. Any idea what's causing this? My right click settings in "options" is still set the way I've always had it.
Running C3D 2013.
OliverE
in reply to: Jeff_M
Is there a way to do this for multiple alignments at the same time?
For your right click setting enter PICKFIRST in the command prompt and change the default to "1". For some reason Autodesk products like to set it to "0" randomly.
Rail Community
