Using Civil 3d2012, Is it possible to change the alignment label style set after the alignment has been created? For example, for an alignment that was created with alignment label set X - change the label set to alignment label set Y? It seems like this should be pretty easy, I must be missing something obvious. Thank you.
Solved by Jeff_M. Go to Solution.
I tried this solution but when I right click I just get the standard shortcut menu, no option for "edit alignment labels".
Is there a direct command for this?
Until about a week or so ago I have always been able to right click on any Civil 3D object and go directly to its properties or styles. Now I only get the standard shortcut menu. Any idea what's causing this? My right click settings in "options" is still set the way I've always had it.
Running C3D 2013.
For your right click setting enter PICKFIRST in the command prompt and change the default to "1". For some reason Autodesk products like to set it to "0" randomly.
