This is a new one for me. I am not running any .net apps that are noit Autodesk's own and loaded by Autodesk without my direct request. I took a snapshot of the error window and then I tried the Retry option. AutoCAD C3D halted (crashed). I suspect Abort or Ignore would have done the same but idk.
Any ideas what this is about (just curious - this post is to inform Autodesk since there was no report interface popup from this crash.
neilyj (No connection with Autodesk other than using the products in the real world)
I have been getting these in Civil3d 2013 since HF2.1 was installed whenever I run any of my custom .net functions.
I didn't install HF2.0 and SP1 has not removed this. If I click Ignore everything works fine & as expected and I do not recieve a crash.
It's really annoying but doesn't seem to be doing any harm.
M.
I am running Windows 7 (64bit) with AutoCAD Civil 3D 2014 and I get this error once or twice a day. I can confirm that if you hit abort it will crash your AutoCAD, however as previously mentioned hitting Ignore seems to clear the error and allow you to keep working on your current drawing. I do not know how to reproduce the error, there are only 2 of us running 2014 in the office currently, and I am the only one getting the error. I have a brand new computer with fresh installs of windows and AutoCAD.
Take a look at: http://usa.autodesk.com/getdoc/TS22358998
I get an error similar to this all the time with hovering over the drawing tabs. It doesn't always happen, but it happens at least twice a day. I can hit ignore and nothing crashes, but it's extremely annoying. I never noticed this until I turned on drawing tabs in 2014.
