coopdetat
Message 1 of 6 (1,117 Views)
Assertion Failed: Removing something that wasn't added?
1117 Views, 5 Replies
01-01-2013 05:44 PM
This is a new one for me.  I am not running any .net apps that are noit Autodesk's own and loaded by Autodesk without my direct request.  I took a snapshot of the error window and then I tried the Retry option.  AutoCAD C3D halted (crashed).  I suspect Abort or Ignore would have done the same but idk.
Any ideas what this is about (just curious - this post is to inform Autodesk since there was no report interface popup from this crash.
Assertion Failed
---------------------------------------------Signature--------------------------------------------
Civil Design Professional Since 1983 (Intergraph), AutoCAD since 1989
Windows 7 Professional 64-bit - Service Pack 1
Intel﴾R﴿ Core﴾TM﴿ i7-3820 CPU 3.60GHz; 16 GB DDR3 Dual Channel RAM
nVidia Quadro 4000; AutoCAD Civil 3D 2014, sp1
neilyj
Message 2 of 6 (1,095 Views)
Re: Assertion Failed: Removing something that wasn't added?
01-02-2013 02:19 AM in reply to: coopdetat
I've had that one as well but i don't have access to my PC at present to see if there was any conclusion.
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
mikeevans
Message 3 of 6 (1,052 Views)
01-04-2013 08:54 AM in reply to: coopdetat
I have been getting these in Civil3d 2013 since HF2.1 was installed whenever I run any of my custom .net functions.
I didn't install HF2.0 and SP1 has not removed this. If I click Ignore everything works fine & as expected and I do not recieve a crash.
It's really annoying but doesn't seem to be doing any harm.
M.
Mike Evans
Civil3D 2013 / 2014 British UK
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
New Member
ChristopherLeslie
Message 4 of 6 (863 Views)
05-31-2013 05:51 AM in reply to: coopdetat
I am running Windows 7 (64bit) with AutoCAD Civil 3D 2014 and I get this error once or twice a day. I can confirm that if you hit abort it will crash your AutoCAD, however as previously mentioned hitting Ignore seems to clear the error and allow you to keep working on your current drawing. I do not know how to reproduce the error, there are only 2 of us running 2014 in the office currently, and I am the only one getting the error. I have a brand new computer with fresh installs of windows and AutoCAD.
rkmcswain
Message 5 of 6 (501 Views)
12-30-2013 02:09 PM in reply to: coopdetat
Take a look at: http://usa.autodesk.com/getdoc/TS22358998
Valued Mentor
engrtech
Message 6 of 6 (490 Views)
12-31-2013 08:37 AM in reply to: coopdetat
I get an error similar to this all the time with hovering over the drawing tabs. It doesn't always happen, but it happens at least twice a day. I can hit ignore and nothing crashes, but it's extremely annoying. I never noticed this until I turned on drawing tabs in 2014.
IDSP 2015
Windows 8.1 Pro 64-bit
8GB RAM
