I start creating an Assembly with a Base Line. Then a Median Sub Assembly is added. I complete the editing of the SubAssembly. (This one file)
Then, I add another Sub Assembly to the Median Sub Assembly. A Warning immediately appears at the Base line. (This is second file)
Would like to know why this is happening. What will be its effect on the corridor, volumes etc that will come later.
What does the error say if you hover over it?
You must have your assembly designed as a single group instead of a left and a right. The median won't work unless there is a left and right.
It is still the same even after adding SubAssemblies on both Left and Right Sides. Please see attachment.
Could you please check this again. I have added the Subassemblies both on right and left. Still the same warning appearing with the same message.
Thanks.
