Civil 3D Forum
Assembly Warning
5 REPLIES 5
sbd123
351 Views, 5 Replies
Assembly Warning
I start creating an Assembly with a Base Line. Then a Median Sub Assembly is added. I complete the editing of the SubAssembly. (This one file)
Then, I add another Sub Assembly to the Median Sub Assembly. A Warning immediately appears at the Base line. (This is second file)
Would like to know why this is happening. What will be its effect on the corridor, volumes etc that will come later.
5 REPLIES 5
tcorey
in reply to: sbd123
What does the error say if you hover over it?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
sbd123
in reply to: tcorey
Here you go.
tcorey
in reply to: sbd123
You must have your assembly designed as a single group instead of a left and a right. The median won't work unless there is a left and right.
Tim Corey
Redding, CA
sbd123
in reply to: tcorey
It is still the same even after adding SubAssemblies on both Left and Right Sides. Please see attachment.
Muthya
in reply to: sbd123
Could you please check this again. I have added the Subassemblies both on right and left. Still the same warning appearing with the same message.
Thanks.
Rail Community
