Active Member
ejfancett
Message 1 of 6 (630 Views)
Assembly Style Marker
630 Views, 5 Replies
10-31-2012 07:18 PM
Anyone know how to turn off the yellow flags.  See the attachment photo.  I click on them and the whole assembly is lit. I am at a loss.  What am I missing?
Any help will be appreciated.
EJ
That is part of the LaneSuperElevationAOR subassembly, no need to remove it.  The potential pivot property controls it.
mathewk
Message 2 of 6 (623 Views)
Re: Assembly Style Marker
10-31-2012 08:28 PM in reply to: ejfancett
Matt Kolberg
Cansel - Autodesk Division
http://www.cansel.ca/
Valued Contributor
wizengr
Message 3 of 6 (598 Views)
11-01-2012 11:19 AM in reply to: mathewk
I thought the flags can be turned off by opening the Properties Palette, selecting the Assembly and then setting the "Potetial Pivot" option in the Tool Palette to "No".
mathewk
Message 4 of 6 (596 Views)
11-01-2012 11:20 AM in reply to: wizengr
Yes, that's what I meant in my comment [...The potential pivot property controls it....]
Matt Kolberg
Active Member
ejfancett
Message 5 of 6 (566 Views)
11-02-2012 09:25 AM in reply to: ejfancett
Thanks!  It is on the subassembly properties.  I should of checked there, but since it lit up with the assembly I was confused.
Valued Contributor
Grimes_MG
Message 6 of 6 (242 Views)
02-28-2014 10:32 AM in reply to: ejfancett
How would you not display and/or not plot the "Potential Pivot" object if your road need one? I am using the assembly as a "typical cross section" in a drawing and the PP object is plotting.
Win7 (x64), EVGA 790i, 8GB RAM, EVGA 8800GT, 250 GB iSSHDD, & RAID 0/1
