Civil 3D Forum
Assembly offsets and corridor parameters
20 REPLIES 20
Message 1 of 21
erogers
927 Views, 20 Replies
Why do the corridor parameters want you to assign a profile to an assembly offset? The elevation at the offset point is frequently governed by the assembly parameters. For instance, cross slope governs when using "hold grade, change offset" on a lane transition, but the corridor still requests a profile be assigned to the offset.
The problem is - if you don't assign a profile, it grades to zero elevation at the offset. If you do assign a profile, it is virtually impossible to define an offset profile that mimics a constant cross slope, and if you update your centerline profile, you have to manually update your offset profiles.
Am I the only one using offsets and having this problem?
20 REPLIES 20
Message 21 of 21
mathewkol
in reply to: erogers
Man that's awful. I've been waterskiing ever since. Heads up dude. The water's fine once you get used to it.
Matt
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Rail Community
